Is this a good resonator? - Performance Forum
Sunday, August 21, 2005 6:32 PM
Brand: FlowTech
BIG-50251FLT
Product Line: FlowTech Red Hots Mufflers
Case Shape: Round
Inlet Diameter (in): 2.25
Inlet Quantity: Single
Inlet Location: Center
Outlet Diameter (in): 2.25
Outlet Quantity: Single
Outlet Location: Center
Internal Construction: Glasspack
Muffler Material: Steel
Muffler Finish: Red
Case Length (in): 18.00
Overall Length (in): 24.00
Case Outside Diameter (in): 3.50
Outlet Style: Standard, without tip
Quantity: Sold individually.
This is 18 bux at summitracing, I will be getting a pacesetter header and a 94035 cat to finish off my exhaust. Should I get the regular clamps or the band style, it will be welded later but not every joint, I want to be able to take it apart if I need to.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Re: Is this a good resonator?
Sunday, August 21, 2005 6:45 PM
No, that is not a good resonator. That is a louvered-core glasspack, which i would suggest staying away from. I would look for the Dynomax Thrush Magnum glasspack. Its going to cost about the same, but it will flow much better because it is a perforated-core glasspack. The part number for the one you would want is WLK-24201. Its 2" longer and cost an extra $2. I hope that helps you.
Sunday, August 21, 2005 9:01 PM
agreed...
Sunday, August 21, 2005 9:05 PM
Check out Thrush or Magnaflow resonators.
Monday, August 22, 2005 12:34 PM
Ok cool, that why I asked, I knew their was a kind that wasn't as good. Thanks.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Monday, August 22, 2005 11:30 PM
I can get glasspacks at work what should i be looking for inside them to stay away from the bad ones?
I don't need no stinking SIG. Wait this is one.
DOH!
Tuesday, August 23, 2005 11:47 AM
Hurmmm what is the Resonator Good for? is it needed? what is the difference in having one ?
Tuesday, August 23, 2005 11:51 AM
Juan Morales wrote:Hurmmm what is the Resonator Good for? is it needed? what is the difference in having one ?
A resonator is used in between your catalytic converter and your muffler (replacing some of the catback piping) to reduce buzzing and quiet down your exhaust, also deepens the tone. It's a good part to have after getting a header and catback, as they create more buzzing and raspiness.
Tuesday, August 23, 2005 12:11 PM
And would thier be a diff on the Wlk 24201 and the WLK-24205<--- longer ??/
Tuesday, August 23, 2005 12:18 PM
Yep its just the length difference.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
