I need to see pictures of a pacesetter header for a 1998 z24 cavy with the 2.4 liter dohc 16v engine. Thanks in advance
anyone else have the same engine with a header or not?
I do. Unfortunately it's the best I have...
<img src="http://www.saskjbody.org/iB_sjc/uploads/post-9-45611-matt_pt.2_2.jpg"/>
Painting the Z - one inch at a time!
sweet man i have a 1998 z24 do we both have the same engine? did you use the stock gasket? what about erg do we both have them or not. i looked up alot of info about my car but it was not detailed is the ld9 quad 4 or not thats what i dont understand.
what brand is that header also?
IIRC it's the black painted one. But I know it's a Pacesetter. I got it off of a friend of mine who owned a parts store at the time. Yes, the engine is a 98, and yes it has EGR although you can't see it in that picture. I would recommend getting a new stock gasket, and using that, although if you are cheap the stock one would probably do the trick. I think I would go with the armor coated one too.... I'm not sure if it will be the same, but with the black one, the first few times you run your car the coating will just burn off, and end up looking like that in the picture. Is the armor coated one silver? The link you gave isn't working for me.
its the pacesetter header , if you reg his registery
and pics have been posted lots of times , a quick search usually will show that
also gravanatuning.com , or turbotechracing
also i recomend getting the armor coated(ceramic) header
i have decided that i will get the armor coat thanks for the info
