which is better??? - Performance Forum
which is better???
Saturday, July 16, 2005 12:21 PM
running way rich, or running a bit lean?
on a side note, I have the gm sc, and my car runs way rich lol. I have no idea what could be causing this, but the way that I know its running rich is whenever our car club caravans somewhere, the person always behind me smells it so......what could it be??
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
Re: which is better???
Saturday, July 16, 2005 2:38 PM
Well more air more fuel, Hows you A/F ratio?
Have you upgraded injectors?
Have you Reflashed your comp?
How much boost are you running?
What size drive pulley?
Have you upgraded your fuel rail?
Have you upgrade anything else in your fuel system?
Have you checked your sensors lately, ie. O2 sensors, map sensor, IAT sensor, etc?
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Saturday, July 16, 2005 4:12 PM
the leaner you get the more power you will make to a point , and that is usually very close to the point the motor will POP
best is to keep the a/f ratio on the 12 range
13's are border line , 14's are POP time
Sunday, July 17, 2005 1:49 AM
You will make the most power on the top edge of the lean side. You have to be careful in this case beacuse too lean... and you'll melt your cyl walls and trash your motor. Running too rich? Eh you'll just shoot flames, foul up your plugs, and bog out a lot. Your PCM will keep you from running too rich or too lean. However, if you can tune it to run just a taaaaad lean at WOT, then you'll be gravy.
Monday, July 18, 2005 9:22 AM
Lawnmowerracer wrote:Well more air more fuel, Hows you A/F ratio?
310cc
yes
4-4.5psi
2.8"
no
no
IAT yes, o2 and map no
what could cause my car to be running so rich? i towed the car to the dealer and got the pcm or whatever reflashed like it said, but it runs way too rich, unless its supposed to. idk if it is or not.
2000 Camaro V6.
Monday, July 18, 2005 9:23 AM
oh and dont know my af ratio, and i should have put this in the boost forum lol.......
2000 Camaro V6.
Monday, July 18, 2005 10:59 AM
ZStreetCavSC wrote:oh and dont know my af ratio, and i should have put this in the boost forum lol.......
then how to do know your running to rich ???
and dont tell us its from the regualr a/f gauge , cause those are about as accurate as the idiot lights on your dash , LOL
Monday, July 18, 2005 6:11 PM
first post please! lol, cause whenever i caravan with people they can smell it
2000 Camaro V6.
Monday, July 18, 2005 11:52 PM
ZStreetCavSC wrote:first post please! lol, cause whenever i caravan with people they can smell it
do you have a cat? now you should know, all J cars run rich from the factory, it's just life. your o2 sensor could be fouled. pull your plugs
Tuesday, July 19, 2005 12:19 AM
well it like magnified it then, cause i never had someone tell me that it was running rich before the sc went on
2000 Camaro V6.
Tuesday, July 19, 2005 12:30 AM
well naturally. do anything like that and your fuel mixture is bound to change.
