Well here is the problem. i got a set of 2.3L HO injectors for my 2.4L . i got them with the rail.... They look almost identical so i figured i could just slap it on there. I then painted and polished the rail, tapped it and installed a pressure guage.
When i went to install it today along with a rising rate regulator from cartech, i noticed that the stock regulator on my 2.4L has a round inlet, and the 2.3L supports some mishapen regulator...will it fit the return line, and will the pressures work right with my motor......
My question is, can i use a 2.3L HO regulator on my 2.4, then i dont haveta start from scratch with the rails.....
thanks
