Help for 96 2.4s...... - Performance Forum
Thursday, June 16, 2005 1:48 AM
So you have a '96 2.4, and you want to get around that damn EGR.........
I have an option for you.
Dk Gry 32 Pin Female
Push-to-Seat
LT1 and Vortec ECM's
Plus several others
Includes colored retainer
listed below.
$24.50
Opening for wires Left/Right (From back of conn.)
Retainer Color (Black,Blue,Clear,Red)
Order up 2 of these, pick up a 95 ECM, and swap the pins. At least it will make you OBD-1, and Chip-able..... I have the 96 and 95 pin-outs saved on my computer. (small change to the Injection harness might be needed (switch from MFI to batch fire))
Delco Connectors
anyway, just something I came across, and thought it might help out somone.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Re: Help for 96 2.4s......
Thursday, June 16, 2005 1:55 AM
Or possibly switch to 97-99 ECM's????
Fits GM vehicle ECM's
of various vehicles and
various years.
Only stock red and blue retainers.
$54.50 (each)
I also have the pin-outs for the 99 ECM....... making it a pretty easy swap. (if these connectors work on those computers, which it looks like it will)
Thursday, June 16, 2005 7:19 AM
Of course, now you find this stuff, after I get a new Cavalier and all
O noes!
Thursday, June 16, 2005 7:55 AM
I would say the switch to 97-99 would be a better idea as it is illegal in alot of states to mess with emissions control devices like here in PA, obd2 to obd2 is ok but not going to something older
Thursday, June 16, 2005 8:15 AM
hmm
Thursday, June 16, 2005 12:18 PM
SpeedRacerZ wrote:Or possibly switch to 97-99 ECM's????
various years.
$54.50 (each)
What do you mean switch to a 97-99 ECU? It is still EGR.
Thursday, June 16, 2005 12:55 PM
97-99 style (99 program) ECM.........
Thursday, June 16, 2005 1:27 PM
so that would be plug and play for switching to 95 OBD1 ECM??????
i mean i plug my harness in that, then that plug into the ecm and thats it?????
that would be awesome!
Thursday, June 16, 2005 6:00 PM
You pull the pins out of your connector, and plug them into this connector....... or if you get one with a pig-tail harness (like second pic) you either cut off your connectors, and butt-connect them together, or you SPLICE into your harness..... (lets you have the 96 plugs, and 97+ plugs)
Soilder, and heat shrink is a must to keep out salt and water......
Thursday, June 16, 2005 6:24 PM
As usual very interesting and useful info. Brian do you think that this connector adapter can let 96+ OBDII cars uses 95 OBDI ecus? could be a OBDII to OBDI adapter like some Honda's ECU trick that I have seen.
Of course could exist other issues due to ecu programming differences.
Anyway great info.
Regards,
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
Thursday, June 16, 2005 7:04 PM
Man you can tell im new to this...not to be a pain but 'repin a harness'? that be awesome to go back to an obdI so if someone could help me understand this crap...thx
"sometimes the respect is more important..."
Friday, June 17, 2005 7:33 AM
i dont think it would be that bad if u are good at following pin outs. it would be time consuming though.
Friday, June 17, 2005 2:31 PM
SpeedRacerZ wrote:97-99 style (99 program) ECM.........
So the 96 ECU, is different than the 97-99?
the Reaper is a 96, and the ECU appears the same from just glancing at it.
Good info.
Sunday, June 19, 2005 1:41 AM
'95 has (2) 32pin plugs (OBD1)
'96 has (3) 32pin plugs (OBD2)
'97+ uses (2) 80pin plugs (OBD2)
Sunday, June 19, 2005 3:12 AM
and im guessing that the 96 z-24 has gotten swaped to a OBD-I ECM and chiped out to a W-41 with some burn on it for timing retard?
if all this is posable. i wounder if somthing like that could be used to make that damn 3800 work in the 94....
nice info...
chris
'02 Z-24 Supercharged
Monday, June 20, 2005 2:44 AM
i thought an dhas been told that the 95 has 3 plugs and 94- has 2!!!
Monday, June 20, 2005 9:27 AM
There's no "magic" in this connector. It's just a connector. You still have to overcome issues like the ipc and airbag modules not talking to the later pcm, and the fuel tank sending unit resistance being different (for some years). Nothing changes in terms of sensor and module compatibility just because the pin locations are moved for a different pcm.
I've got the pin locations for various year/ engine J cars on an Excel spreadsheet. Glad to forward if needed.
-->Slow
Monday, June 20, 2005 10:04 AM
what would blocking the EGR do?
Monday, June 20, 2005 5:06 PM
hey slowolej, would you email me the excel sheet of 95 ecm and the 97 ecm please?
Thats a project i have, convert to obd1!
thanx!
Tuesday, June 21, 2005 12:28 AM
never said there was any "magic" in these connectors.......... but thanks for trying to be an ass.
As of yet, I have yet to run into a problem in compatability from 95-98....... or from 97-99...... Yes, 00+ things like the Fuel Level sender are different...... and ABS/Air Bag systems..... I guess when someone runs into a problem, we'll work around it, just like we worked around the EGR...... and how Nick (changeforabutton) got the 00+ pcm/bcm to work on his '98.
why would anyone need them, since this is just a waste of time?
Magik1109 wrote:hey slowolej, would you email me the excel sheet of 95 ecm and the 97 ecm please?
thanx!
NY-Jbodies should have all the info you need for those pin-outs.
