For those of you who have put 2.4 / 2.3 on dyno - Performance Forum
Friday, June 03, 2005 11:25 PM
where the HELL do you get a tach signal for the dyno on one of these engines short of removing the IDI & puttin plug wires on it? I talked to Kevin @ PAS and he says he needs either a plug wire or a individual coil feed wire to get a signal. any help would be appriciated, i am trying to avoid ghetto rigging it just to put it on the dyno.
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
Re: For those of you who have put 2.4 / 2.3 on dyn
Saturday, June 04, 2005 10:38 AM
Pink wire that comes out of the IDI wire harness. Put the clip on it, just as if you were putting it around a spark plug wire. Then you'll have to calibrate it for number of cylinders to get it to read the same as your in dash tach.
<img src=http://ourworld.cs.com/jwithspray/Nitrosig13303.JPG>
Saturday, June 04, 2005 12:07 PM
yep ^^ pink wire on the idi harness. the signal will only be 1/2 the tech, just set the dyno appropriately.
14.82 @ 97 mph
Saturday, June 04, 2005 1:08 PM
As said the pink wire is tach signal. When I have been on the dyno they always put the clip around the whole wirinf harness going into the IDI cover and it works.
Saturday, June 04, 2005 10:35 PM
ahh damn. to late. we allready got ghetto and removed the idi and jumpered it with spark plug wires. will know next time! they tried a few of the wires on the harness with no luck. but eh . this was the first time ive dynoed the car + its the first j body period on the thing there
It put down 127 hp 129 torque. bone stock automatic sunfire gt. im content with those numbers for a baseline.
Thanks for the responses to bad I read em to late. DOH!
