Why the LO cam for secret? - Performance Forum
Thursday, May 26, 2005 1:50 AM
Well the head and cams etc are all out of my car, and I have a ported/polished head on the way, but I have a question about the secret cam swap:
Why use a LO exhaust cam with less litf at .360 than a HO cam with .410 lift? Wouldn't the HO cam yield more power, or would it be open too long or what? I am not a cam guy, and was just wondering which cams to go looking for and why the exhaust cam for the swap was chosen.
22 miles per gallon and dropping fast...
Re: Why the LO cam for secret?
Thursday, May 26, 2005 2:11 AM
Ohh and I have a friend that is telling me to just send my stock cams to crower cams and they can have them re-ground cheap, he wants me to use W-41 specs for the re-grond or true HO specs, what would the advantages be to the secret cam install?
Thursday, May 26, 2005 8:05 AM
because you need the 95 2.3L intake cam out of a 95 and only out of a 95 due to the machined hex head in it to drive the power steering pump.. and i believe the 2.3 LO cam is the best cam to complement it with the closest specs..
15.69@86.670 - stock 99Z
Thursday, May 26, 2005 8:10 AM
The HO cam is too aggressive for the stock ECU.
Thursday, May 26, 2005 8:25 AM
no cam sensor , power steering , and cam wont fit in the towers with out machining
Thursday, May 26, 2005 8:28 AM
HO cam=car runs like crap. The HO grind is too aggressive and the PCM freaks out and doesn't run right. The LO cam is a very good improvement over stock, but, isn't so aggressive that the PCM stays happy
Thursday, May 26, 2005 8:52 AM
JoyRide wrote:because you need the 95 2.3L intake cam out of a 95 and only out of a 95 due to the machined hex head in it to drive the power steering pump.. and i believe the 2.3 LO cam is the best cam to complement it with the closest specs..
^^^^^agreed
Thursday, May 26, 2005 10:35 AM
Thanks, didn't think of the problems with the ECU with the HO or W41 cams. Hopefully I can find some now relatively cheap...
Thursday, May 26, 2005 10:58 AM
the Ho cam with the Ho chip will miss at 900-1000 rpm and it will be stalling if you go slower so it's a big no for the 2.4 Auto
W41 cams will stall at 1100-1200 with the W41 chip so it's a No for any 2.4
another thing, Karo had a modify W41 chip/ecm and W41 cams on his build 2.4 and he had some weird number. Really high torque and no Hp. The Ho cams were better.
But you ask for the EXHAUST cam, it shouldn't cause any problem with an Ho cam but the housing may need to be modify.
Gilles
2.3 Ho
Thursday, May 26, 2005 6:15 PM
use the HO housing!!!
Thursday, May 26, 2005 8:05 PM
just curious im more of an eco guy so i dont know to much about this swap. but why not just put the whole head off a 2.3 on the 2.4 block.
-Brandon
Friday, May 27, 2005 2:24 AM
you can do that too but you have to modify the head (IE drill the coolant hole) and use the 2.3 manifold. Yes it's better than stock.
Why people don't want to do it? the 11.4+ compression it give after the head swap. Alot of people don't want to put 91+ octane and work on a head that crack under heat.
Gilles
2.3 Ho
Friday, May 27, 2005 5:10 PM
but if you drill the coolant hole, would that not fix the overheating prob?? hell i put 93oct in my eco and all i have is i/h/e. just sold the nitous kit. but still use it.
-Brandon
Friday, May 27, 2005 11:03 PM
My 2.4 head is ported and polished for the HO manifold and I am thinking of having a little shaved off the bottom to up the compression anyway, so I don't need a quad head.
You said it wouldnt be a problem to use the HO cam in the swap, but would there be any power gain? I doubt it would be very much.
Saturday, May 28, 2005 11:32 AM
milling ur head won't get it anywhere near the 2.3 head swap would in compression ratios
cavaliers been laid to rest
The saturn is being born
a new cavalier is in the mist
Sunday, May 29, 2005 1:36 AM
He asked about the exhaust cam....
Mark P.
