My port Job - Performance Forum
My port Job
Sunday, May 22, 2005 2:58 PM
Currently in the stages of finishing my porting job for my 2.2 OHV. My only question is, what FPR can i use. I have done a couple of searchs and every one talks about how they are having a hard time puting this aftermarket ones on and how they have to make different adjustments to make them work. Can any one show me some pics or give me advice on which one really does work. Preferably looking for something red with gauge. If you look below the old one looks hideous with the new paint job.
Re: My port Job
Sunday, May 22, 2005 3:09 PM
accel makes one for the covette that some people use in place of the stock one....
Re: My port Job
Sunday, May 22, 2005 3:11 PM
Event , do you know where I can get it?
Re: My port Job
Sunday, May 22, 2005 3:25 PM
took me some time to find the old post
http://www.hopupracing.com/acadfuprreco.html the part
the post....
http://www.j-body.org/forums/read.php?f=40&i=52511&t=52475#52511
some say you can get it off ebay for 60
others have listed a few other places i was seein scannin through em, might be worth a look
http://www.j-body.org/forums/search.php?f=40&search=corvette+fpr&globalsearch=0&match=1&date=0&threadtype=&fldbody=1
Re: My port Job
Sunday, May 22, 2005 3:40 PM
Thanks , Event, seen a couple of these and some are new.
Re: My port Job
Monday, May 23, 2005 12:47 AM
Personally, I wouldn't use an FPR. I would defenitley recommend an SAFC-2. I have it and it will work with all J-bodies. For instructions on installation you should either search or make a post on how they install.
With an SAFC-2 you can control where you need fuel or where you don't need fuel on what RPM range.
Here is a picture of what it looks like:
<img src="http://memimage.cardomain.net/member_images/8/web/584000-584999/584592_39_full.jpg">
Also, looks cool when it lights up...
You might want to invest in an Air/Fuel ratio gauge or a Wide-band
Good luck with your decision...
Re: My port Job
Monday, May 23, 2005 1:59 AM
actually a adjustable fpr is a needed item , cause you can get a stable base fuel pressure
not all the stock fprs had the same base pressure
Re: My port Job
Monday, May 23, 2005 2:49 AM
[quote=97cavie24ls(JDM cav sedan™)]actually a adjustable fpr is a needed item , cause you can get a stable base fuel pressure
Possibly for his car his base pressure isn't as high as mine. What I found was that the more I did, the more fuel my computer was dumping into my motor so I ended turning the fuel DOWN instead of up. I'm not sure with the OHV but I know for the ECOs, their computers tend to run rich (I know more than myself with heavily modded ECOs) when not under boost.
Re: My port Job
Monday, May 23, 2005 6:17 PM
Thanks guys for the Advice. I will be making a desion on what i want to do soon. waitning for throttle body to come back from the shop.
