I am looking to do the crane cams roller rocker swap in my 95 2.2. Now what i need is info from people that have done this swap. I need part numbers of what i need and correct information..the reason i posted this instead of going from my search is everyone has differnt ideas of what has to be done...ie some say keep stock pushrod guides and others say just use a washer and no guides. So again i need all the correct info and part nubers and so on...thank you for any help..phil
Also id like to know if i should change my pushrods and with stock or what and part numbers? And does anyone know if it will help get rid of my liter ticking??thanks again ...phil
lifter tick is generally a seized lifter.. sometimes a similar sound can result from a loose rocker nut.
everything you need to know about the roller rocker swap is on that link.
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/toond.jpg"></a>
pick up a brand new set of lifters and pushrods, and check out the Crane Cams roller rockers at
Howell Automotive
Yah i checked them out but they dont have a listing for 95 -97 so i dont know..how hard is it to change the lifters??also i found the nj jbod site very confusing....anyone have a better how to??? and parts list??? thanks..phil
Philly D wrote:Yah i checked them out but they dont have a listing for 95 -97 so i dont know..how hard is it to change the lifters??also i found the nj jbod site very confusing....anyone have a better how to??? and parts list??? thanks..phil
the comp cams rockers for the 95-97 i ordered from Summit Racing. it's cheaper to order the set of 12 than individually. the part number is CCA-1414-12 for the rocker arm kit. order pushrods from wherever, doesn't really matter. the rocker studs you will need to pick up from a GM dealership. the part number the rocker studs is 476530.
^^^ you wouldnt happen to have the part number for crane cams roller rockers would you???phil
Philly D wrote:^^^ you wouldnt happen to have the part number for crane cams roller rockers would you???phil
crane cams does not have a roller rocker kit for the 95-97 2.2
it's comp for 2.2
crane for 2200
