2.3 HO Swap, STUPID EGR!!! What Do I do With It? - Performance Forum
Tuesday, May 17, 2005 6:30 AM
I cant get the engine in the car until I have this figured out so I need HELP! WTF should I do with it, the instructions arent that clear, what have other people done? I need pics or something, thats is terrible!!!! I want my damn car on the road so someone help.
Thanks
Chris
Re: 2.3 HO Swap, STUPID EGR!!! What Do I do With
Tuesday, May 17, 2005 8:28 AM
block the egr port , either from the gasket on the exhaust manifold , or make a plate for the front of the head to block the port
ive did the 99 pcm swap on mine , so i didnt need the egr simulator , but you have to have a 99-up knock sensor , and have to run a extra wire from the knock sensor to the pcm , as well as move a couple pcm wires
Tuesday, May 17, 2005 1:51 PM
I have a 99 2.4 going in, does that make a difference?
Tuesday, May 17, 2005 4:25 PM
like he said block the egr.
Wednesday, May 18, 2005 8:40 AM
if its a 99 motor...no need in blocking...the manifold probably doesn't have the provision for the egr port. Do what I did...tap the hole, insert a nipple fitting, and run vacuum line back to the intake manifold.
