Repinning Harness - Performance Forum
Repinning Harness
Saturday, May 14, 2005 5:00 PM
i was in an HO intake thread and someone said something about repinning the harness and it would change ur rev limiter to 6800 rpm's. could someone tell me what i would need to do this and how i would go about doing it. thanks
"sometimes the respect is more important..."
Re: Repinning Harness
Saturday, May 14, 2005 5:14 PM
on a 2.4L or 2.3L
Sunday, May 15, 2005 6:20 AM
read it again.
I didn't say that you had to just repin the wiring harness.
You need an Ho ecm and then repin the harness. But you didn't even put what car you have. 96 and maybe some 97 2.4 can be repin for the Ho ecm but if you have a 97+, forget it.
The Ho ecm will have a rev limiter of 6800rpm, not the 2.4 ecm.
Gilles
2.3 Ho
Sunday, May 15, 2005 7:42 AM
I have a 96' 2.4 so by doing the ho swap i will get that new rev limiter?
Sunday, May 15, 2005 9:54 AM
yes but it doesn't give you anything more. you won't gain more power than 1-2hp and you'll be reving for no reason past 6200rpm
Gilles
2.3 Ho
Sunday, May 15, 2005 12:02 PM
past 5500 rpm oil pressure drops off too
<img src="http://registry.gmenthusiast.com/images/snowman/thumbnail_sunfire.gif">
<img src="http://registry.gmenthusiast.com/images/snowman/thumbnail_personal_pic.jpg">
Monday, May 16, 2005 7:27 AM
so is it a good mod to spend the money on or is it not worth it, i heard it takes off the govenor too and that is another thing i would like
Monday, May 16, 2005 7:47 AM
there's no point in having a higher redline if you aren't making power up there. dropping oil pressure is a negative also.
Monday, May 16, 2005 9:07 PM
Thats why you need to have the setup I have.....
2.3 oil pump swap
2.4 block
086 head
pnp head
Hyperuetectic sealed power pistons
stock crank and rods
Now I am looking to do the OBD1 computer from a 91 HO Grand Am, plus adding the w41 chip. I want the better fuel curves and tuning abilities.
