Full Exhaust - Performance Forum
Full Exhaust
Friday, May 06, 2005 5:03 AM
just ordered. let me know if you see anything missing.
SLP stainless-steel exhaust system
PaceSetter Exhaust Headers
2.5" x 6" Flex Pipe
2.5" Magnaflow Catalytic Converter w/ 3 bung holes
Header wrap tape
AEM intake
figured all i need now is a tb and intake manifold and ill be done with airflow(untill done with turbo setup) then start fuel
________________________________________________________________
Click My Sig For My Website
Re: Full Exhaust
Friday, May 06, 2005 5:20 AM
Maybe a 26-30" resenator to keep it quiet? If the exhaust system doesn't come with a muffler, get the Dynomax Super Turbo muffler, other than that, good choices, IMO.
Re: Full Exhaust
Friday, May 06, 2005 6:56 AM
yea it does. the SLP is a full catback. Hope i dont run into problems trying to run it to the cat. the slp is made for a v6 but it should be ok. i have the superturbo on right now with the stock res. to quite for me. im going to try it and if its too loud ill but one on. thanks for the reply
Re: Full Exhaust
Friday, May 06, 2005 8:11 AM
No prob, make sure to get pics asap!
Re: Full Exhaust
Friday, May 06, 2005 8:40 AM
you did just order one right?
Re: Full Exhaust
Friday, May 06, 2005 9:41 AM
Ok...well first off, do not put header wrap on a header.
and second...if you are going to be putting a turbo on there, why buy a header? Unless the turbo is years down the road.
Finally, with a header, I would recommend a resonator.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Re: Full Exhaust
Friday, May 06, 2005 11:05 AM
I have the SLP on my 2.4L Malibu and I am pretty sure you are going to want a resonator put on. I was pretty loud for me and I din't like the ricer sound I was getting at higher RPM's. Even with a resonator I still get some of that sound so I am planning on changing out the muffler.
Re: Full Exhaust
Friday, May 06, 2005 12:15 PM
yes i got only 1 header. i just cut and pasted that from site. now the slp on you malibu at idle can you hear it at all.
why wouldnt i put the tape on the header?
and yest turbo is going on my new motor im building. not going to put it in untill 100k. im at 12k right now. so turbo is very very far down the line.
Re: Full Exhaust
Friday, May 06, 2005 12:23 PM
You can still hear the rumble at idle, it just isn't very loud. The only reason I got a resonator is because I hated the sound I got at above 2,000 RPMs(the ricer sound).
The reason you don't want the header tape on is because it keeps moisture in and it would rust out a header.
Re: Full Exhaust
Friday, May 06, 2005 12:24 PM
here is a link about the haeder wrap:
http://www.j-body.org/forums/read.php?f=2&i=301150&t=301150
Re: Full Exhaust
Friday, May 06, 2005 12:25 PM
Tape holds moisture on the header and causes it to rust. Also, it voids the warranty of the header.
-da chinchilla
Re: Full Exhaust
Friday, May 06, 2005 1:24 PM
just dont understand why gm wraps a bunch of thiere headers? i saw a v6 impala today and the exhaust manifold was all wrapped up.
Re: Full Exhaust
Friday, May 06, 2005 8:23 PM
Must not have come stock like that.... i dont know of any headers that have a wrap on them... heat shields yes, but no wrap.. not only with your header rust , it can cause it to warp since your holding all the heat in.
Supercharged 2.4L
