another TB question but this one is dif. I promise - Performance Forum
Sunday, May 01, 2005 8:20 PM
I have 2 Tb's right now.
1 is a 52mm from a 99 2200.
the other is a 56mm from a 2.3 quad 4
how in the world do the butterfly plates come out. I tried everything. I have no idea how to do.
The reason I need to do this is because I want to use the butterfly from the 2.3l so I can get the 2200 bored out to 56mm.
any ideas??
Re: another TB question but this one is dif. I pro
Sunday, May 01, 2005 8:33 PM
after you remove the butterfly plate screws it should just come right out but i could be wrong with thsoe TB's. thats the way my Eco came out
04 sunfire auto, mid 15's n/a, and still going
Sunday, May 01, 2005 8:36 PM
Sunday, May 01, 2005 8:39 PM
the 2.3 tb i don't think will work.
i test fitted in on the IM and there is a gap and only has 3 mounting holes instead of 4.
and Roy i can't seem to get the stupid bolts out of either I tried for hours. lots of wd40 used..
It might be because i am using a dumbing screwdriver type torx wrench. I might have to buy a socket set torx wrench.
Sunday, May 01, 2005 8:45 PM
I just took the plate out of the one i got from the junkyard... the two screws will come out.. they're a torx bit.. i don't know what else to tell you.. but the plate will only come out one way.. there's two "bumps" on one side that don't allow it to drop through a certain way. i'm guessing they'll be on the side that's on top when at wot.
so once you take the two screws out... turn it to wot and pull up.
15.69@86.670 - stock 99Z
