On the earlier 2.2L's (97 earlier) GM used a 1.5 rocker arms with a camshaft lift of .432 . When GM changed the 2.2 to the 2200 in 98, they started using a 1.6:1 ratio roller rocker arms with a camshaft lift of .420. To keep the valve lift the same they lessened the lobe lift on the cam. So in theory by doing the swap you will get a cam and rocker combination of .460 inch valve lift, instead of stock .420 lift.
What kinds of gains would this make on my car?
There is no secret
The timing on the two motors is different
So it WILL NOT work
Get a custom cam done
