im reading a lot on wheel hop with the high mods. i have minor wheel hop depending on where i launch but thats on a 99 Z wit only exhaust, TB, intake. but im runnin boost in less then 2 weeks starting tomorrow um ill be gettin the upper and lower mounts.. what else could i get for just minor. strut tower brace? idn much about preventing wheel hop but i saw that the upper mount does some i just want that little extra cuz wheel hop suxxxxxxx..
Better suspension will help a ton, better tires will also help as well. Control arm bushings are good to . . . . there is alot which you cna do just depends on how far your judget will take you . . .
Like Karo said use polyurethane bushing in the control arms . Also a subframe brace can help . If you can find them tubular control arms would be stiffer and would keep the geometry of the suspension from changing when launching .
The biggest thing is to practice launching and learn what works best for your car . Still like Karo said there are a lot of things you can do .
<a href="http://users.adelphia.net/~rdbryant1/index.html.html"><img src="http://registry.gmenthusiast.com/images/mrgoodwrench/personal_pic.jpg" border=4></a>
