2.3ho mani fit to 2200 - Performance Forum
Tuesday, April 26, 2005 7:34 AM
i have a ? would a 2.3ho and 2.4 intake manifold fit onto a 2200 head or should i just buy the intake mani from rsm. and if i should do that is it worth it. thanx
DRIVE HARD OR DONT DRIVE AT ALL!!!
Re: 2.3ho mani fit to 2200
Tuesday, April 26, 2005 9:08 AM
Ports are much larger on these manifolds . Are you looking at their ported manifold for a 62mm T/B ? If so then you could do the same thing with your intake . All they did was use a die grinder or dremel to open up a stock intake so the butterfly on the T/B does not bind .
If anything just pick up the T/B and port your intake . It is plastic and easy to do with a dremel . Just remember not to take out the O-ring with the dremel .
<a href="http://users.adelphia.net/~rdbryant1/index.html.html"><img src="http://registry.gmenthusiast.com/images/mrgoodwrench/personal_pic.jpg" border=4></a>
Tuesday, April 26, 2005 10:54 AM
2.3 HO wouldnt work. the throttle body would be on the wrong side of the engine bay.
Just do what black ops said and port your manifold with there throttle body
l8tr
does that say premium, Oh snap, my membership ran out!
*** rolling on the floor having AG withdrawels ***
must... renew...membership...must...support...org
Tuesday, April 26, 2005 11:07 AM
ok thanx. how hard is it to port the manifold and what kind of atachments would i need.
Tuesday, April 26, 2005 11:09 AM
hey black ops. i too live in va. (hampton) would u ever consider doin a 3400 swap 4 some cash. cause that $hit is sick
