ok ive been doing a lot of research on a @!#$ load of parts. now my question is will these help or make me slower or end up breakin somthin
can you guys let me kno
stage 2 cams
levelzero cam gears
runnin slicks
anything else i should get for upgrades
not sure abot the cam gears, but the cams themselves supposed to add 20 hp
and running slicks will get you more traction for the track
The cams will definitly show you they are there, i dont know about the cam gears. If there ajustable ones then I guess there good if you can safely advance it a little. Slicks would probley make you go slower intill you get more power/ intill you NEED them. I would start with lowering the suspension for more of a grip and better 1/4 mile time
<h3><b>Speed costs... How fast ya wanna go??</b></h3>
<a href="http://mywebpages.comcast.net/pj1987">My old cars</a>
koo koo, thanks. im up for more info if you got some
Im personally thinking of getting that b&m shift kit that they have talked about here. Someone said it took .4 off there 1/4 mile time+ its better on your tranny. longer life
WTF? Level Zero sells cam gears now? You sure those aren't the GM cam gears?
the B&M shift plus for the automatic trans will only take off like .1 or .2 quarter mile time. It makes your car shift a lot harder.
I got a 58mm throttle body and I felt a better pull out of it than any other bolt on that I got. I cant wait until I go to the track to see my numbers this year.
04silvercavy wrote:the B&M shift plus for the automatic trans will only take off like .1 or .2 quarter mile time. It makes your car shift a lot harder.
it really depends on your time already. if your running a lower time its not got do much but if your stills tock it could take a good bit off your time. like, 14.5 seonds vs 17.5 seconds
thanks for the info, yea i have the b&m right now and it did knock off some time, not much but anything lower is better. adventually i wanna be fully built with turbo. but right now just puttin part after part in to get where i wanna be. yeah i have the 62mm tb and it also helped. i think the tb makes quite a difference, more towards performance but also smoother idle
and yeah they are the gm gears, i got mixed up
