ecotec swap into 01 2.4 (yes I searched) - Performance Forum
Friday, April 22, 2005 1:52 AM
The 2.4 in my 01 Z24 bit the dust last weekend and I can't find another 2.4 to replace it with. I can get an ecotec for half the price of a 2.4 if I could find one and there are tons of eco's to choose from. My car is a 5 speed and I am wondering what parts I would need to do the swap?
I know that I will need the Ecotec PCM and I'm sure the wiring harness as well, anything else?
P.S I did search and all I could find was people telling people to search so if someone could help me I would really appreciate it thanks.
Re: ecotec swap into 01 2.4 (yes I searched)
Friday, April 22, 2005 5:22 AM
Ok, well you need a tranny, engine bay wiring, BCM, ECU, motor.
Also the info is out there on the ecotec swap.
Friday, April 22, 2005 9:25 AM
motor , trans ,eco clutch , uppermount , engine side harness , pcm and the bcm from the same car
the rest you can use from your car now
Friday, April 22, 2005 9:26 AM
forgot the radiator , the hose fitting is in a different , you will need the hoses and lines that go with the eco , except the pwr steering lines
Friday, April 22, 2005 10:44 AM
Actually you do not have to have the motor mount, you can use the 2.4 motor mount, and actually the 2.4 mount is better than the stock ecotec mount.
