will monza catback exhaust attach to stock cat? - Performance Forum
Friday, April 15, 2005 10:27 AM
im looking at this:
http://www.highrevmotorsports.com/catalog/product_info.php?products_id=126&osCsid=822903648740da0537c1db2d8d8621de
its a Pacesetter Single Cat-Back Exhaust, and im wondering if the piping that this comes with will attach to the stock cat on a cavalier 2.4L?
im hoping ill be able to buy this, then just bolt it on like it says, without buying a new cat.
also: will the 2.25 inch piping be ok for a 2.4L for max. power? ive heard some people say use 2.5 inch piping for natrually asperated 2.4Ls for max. power, and i have heard some others say only use 2.25 for natrually asperated 2.4Ls.
thanks for the help!
Re: will monza catback exhaust attach to stock cat
Friday, April 15, 2005 2:31 PM
It will attach. Kinda pointless, but it will attach.
The main restriction is the small diameter from the exhaust manifold to the cat...and the cat itself has a very small diameter inlet.
But yes, it will attach.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Friday, April 15, 2005 3:03 PM
no kidding.. why get a cat back? you still have the 1 7/8" I/D down pipe,,, onece you slow exhaust velocity down, there is no speeding it back up... so the cat back is pointless! WASTE OF MONEY start with a header, then get a high flow cat, then muffler and a res... with that money for the cat back, you can buy the pacesetter header, i would save a little more, and get the ceramic coated though....
Friday, April 15, 2005 11:57 PM
a few reasons i want to do the catback first. firstly, i can get the monza catback exhaust for around 150$. second: my friend has access to a mechanic lift, but he only has access to it for about another 3 weeks.
so im going to install the catback while we still have the lift, then in a few weeks i will get the pacesetter header w/high flow cat. that stuff will be easier to install while the car is on the ground.
