performance valve springs! finally! - Performance Forum
Tuesday, April 12, 2005 10:14 PM
about time someone came out with these. apparently my stock springs bind with my cams.
http://www.jbodyperformance.com/new/PartList.php?catId=18&catName=Valvetrain&subCatId=95&genId=3&genName=3rd%20Generation
Re: performance valve springs! finally!
Tuesday, April 12, 2005 11:18 PM
You can use the HO valve springs......... I do. Just use your retainers, and the HO 'hats'
or get those....
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Wednesday, April 13, 2005 5:25 AM
hmm, what diameter are the coils and whats the poundage of the HO springs at max lift in comparison to the JBP valve springs?
Wednesday, April 13, 2005 10:46 AM
sorry to jack the thread, but What are retainers? I'm gonna go get a HO head from the wreakers, is there a specific year i should look for? what is the advantage of using the HO springs?
Monday, April 18, 2005 5:45 AM
*bump*
Monday, April 18, 2005 7:58 AM
I havethe 2.2 springs. Very nice i must say. I got them because i thought they were the only ones available, but then again, chromemoly steel is the @!#$z. won't break, thats for sure.
It doesn't say the material for he 2.4 springs specifically, but says "high strength steel"
here's a link to some pics of my 2.2 head with the springs
here
Monday, April 18, 2005 11:26 AM
nice, but Im wondering about more information about JBP 2.4 springs vs. 2.3 HO springs.
Monday, April 18, 2005 7:59 PM
anyone know the part numbers for the HO springs and retainers?
Sunday, November 12, 2006 6:11 PM
does anyone know the specs on a 2.4 valve spring, what other valve springs are known to fit? oh yeah and what is the part numbers on the HO springs and retainers
Sunday, November 12, 2006 7:58 PM
im using beretta gtz springs in my head, work great.
Thursday, November 23, 2006 8:42 AM
Couple questions about the springs you are using.. I might be getting some springs I will find out in about a week if I have to. What part number did you use and are all the 2.3 DOHC springs the same??? does anybody have information on lbs/inch??
Saturday, November 25, 2006 2:50 AM
I think the 2.4 springs are rated at 70# on the seat and the HO springs are 85# or 90# on the seat iirc but I don't rember the open pressures for either of them I just know the HO are stiffer and can handle up to .430" lift.
2000 Z24 5spd header & catback for now.
Sunday, April 08, 2007 10:53 PM
ok so if you buy an aftermarket cam set-up then would it be best to get aftermarket sorings or could you use Ho springs I am trying to figure this out so i know what all to buy.
Sunday, April 08, 2007 11:46 PM
Iam using HOs with my N/A build should work great iam also running jbp stage 2 cams.
I got my springs from napa. Just ask for any dohc 2.3l quad springs they are all the same. i just asked for beretta gtz springs.
