Well got my exhaust patched up and fixed halfway decent still have some leaks that I will fix tomorrow but while under the car after running it to check for leaks i found water leaking out of both of my air leaks? i'm figuring it might be nothing but I'm unsure. I also have a code thrown for my exhaust being rich I believe it was. I'm not sure what is now. I plan to get my hands on a code reader for the weekend and once i get it I will post the code number.
If you only let the car run on idle, you'll have alot of water in the exhaust. People just don't know how much water is produce and how much can stay in the system.
Gilles
2.3 Ho
That is what I though, But was amazed because the car hadn't really been idling. that long. : / Well gotta finish fixing the exhaust leaks and it should be all good! Thanks
That's the reason the muffler get bad and worn. If there was no water in the system, it wouldn't rust.
Gilles
2.3 Ho
well not on the inside anyway.
It would still rust on the outside from road spray.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
