I just got my oil pressure gauge installed on my ecotec and I was just wondering what psi you guys are getting once the engine is up to temperature?
120+ psi WOT.
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's
----12's
![](/global/images/emoticons/ag.gif)
----11's
----10's
120+ psi, what kinda show are you running under there?
Well you guys can laugh all you want, but I ''AM'' the one that has the Turbo and Eco and trust me I have checked the oil pressure on my Autometer gauge.
Not being cocky and sure not the only one.
If you do a research and look into the Eco build book you will see that you all came off looking as NEWBS. for not believeing me.
Also, I have a Autometer gauge that goes up the a 100 psi on a 270 degree turn and it makes a 360 back at 0.
THAT is how much oil pressure Eco has at WOT.
At idle anywhere from like 70-85 psi. I am not sure but think it is te same cold as hot or maybe a little less hot.
Well anyways I took the gauge off so that it doesn't break and leak cause of so much psi.
So get back with me NEWBS. when you check your oil pressure.
13's
----12's
----11's
----10's
Mine is anywhere between 37.5 - 54.5 on a cold start at idle.
After it warms up between 25-37.5 at idle.
If its really cold out and I take it for a spin before it warms up I can get the oil psi gauge to peak at 100 under wide open throddle conditions.
Mine is an autometer Phantom series electric by the way.
My 2k3 cavalier |
Nebraska Region SCCA
yeah my ecotec is the exact same as tommy boy's, suncavi- just because you have a turbo doesn't make your oil psi go up. when i cold start my car i can get the psi to go up to like 100 but once it warms up it comes down.
Yeah Gm's guide to the ecotec says that oil pressure is 50-80psi at 1000rpm
Here is the hand book if you want it
Ecotec Guide From GM
*2012 mazdaspeed3*
did you guys run the stock pressure sensor or aftermarket.............i've got a 96 2.2 and i was wondering how close the stock senders are between the 2 motors.......
i've got 3 wires running into mine but can only really run one off the new sender, other 2 wires are for fuel cutoff-----wondered what you guys did with the extra wires, if you even have them
