Header 2.2L ecotec 05 sunfire exact fit bolt on - Performance Forum
Saturday, March 26, 2005 11:02 PM
Do they make a header for this engine that does not have any cutting welding or clamping to stock exhaust just a exact bolt in upgrade replacement? This car will not be a full blown race car. Just want a quicker than most stock cars on the street.)Just to have some fun with) Other basic low horse mods will come later this first is what i have decided on . If they make one that i think with suit me. Reliabilitly is a must though so now full race tips please. Thanks to those that respond
Re: Header 2.2L ecotec 05 sunfire exact fit bolt o
Saturday, March 26, 2005 11:26 PM
1.) Read the sticky at the top of this forum.
2.) Do a search, for "header". There are hundreds of posts on different headers.
Tim
"Hey man is that a Cavalier?" "Yeah." What you got in it?" "It's stock." "Oh."
Dimebag
Darrell
Abbott
R.I.P
8/20/66
12/8/04
Sunday, March 27, 2005 7:30 AM
To answer your question. No there isnt a header made that doesnt have to be welded. The stock Cat. is welded to the exhaust, so you either have to cut the stock cat. off the exhaust and have it welded to the new header or just have a new cat. put in. Although some of us have check engine light problems with after market cats. and some dont
Sunday, March 27, 2005 8:11 AM
I think mantapart or high rev or somethign sells a stock exhuast manifold thats ported... thats an exact fit but a waste of money
Sunday, March 27, 2005 8:57 AM
ok thanks then i dont think i will do it. dont want to void warrenty with a major change need to do things that can be removed if i need to take it in. thanks for the info.
Sunday, March 27, 2005 9:02 AM
your not going to void your warrenty. look up the Magnuson-Moss Warranty Improvement Act. basically it says if you add a short throe shifter to your car and something goes wrong with your tranny then the dealership would have to prove that short shifter caused the problem
Sunday, March 27, 2005 9:17 AM
Ok then who makes a good quality one with a flex pipe on it i dont know if i want to put the better engine mounts on it ,cause of the extra vibrations. To those that have is it bad or hardly noticable now the ol lady uses this car alot and dont want her nagging that somethings is wrong when there is not if ya know what i mean.
Sunday, March 27, 2005 9:36 AM
The vibes are not that bad. I assume you already read the posts on the mounts though? You could get the rksport one but I dunno about the rk header. Pacesetter is good, but you don't wanna use their gasket and no flexpipe. I would buy the pacesetter ceramic coated and get a new oem gasket and you will be fine. It has a good tone, and seems like it gives some good gains. You will not be disappointed. Getting it welded will only cost a couple dollars also, just do not use that paper gasket, it sucks. Good luck
<a href="http://www.liquidgeneration.com" target="_blank"><img src="http://www.liquidgeneration.com/quiz/images/villain_hannibal.jpg" border="0"></a>
Sunday, March 27, 2005 9:44 AM
ok thanks on the info i can do all the labor i can do all the work here just did not want to alter the stock pipe but if i have to then no chioce then. if it wont void the warr then i will do it does the aftermarket cats help (worth it) i mean since i will have to cut near it any way?
