Show me your 2.3 HO manafolds - Performance Forum
Thursday, March 24, 2005 9:40 PM
I have mine and it has been worked over to fit on a 2.4, but there are a few things I want to grind down and make it smoother then it is now. So you got pic's I want to see them. I'm going to do something very nice to it, but I want to make sure I can grind down the things I think I can. Thanks. I will be post mine tomorrow cause my batterys are to low right now.
Re: Show me your 2.3 HO manafolds
Friday, March 25, 2005 5:35 AM
TRD Cav Fire wrote:I have mine and it has been worked over to fit on a 2.4, but there are a few things I want to grind down and make it smoother then it is now. So you got pic's I want to see them. I'm going to do something very nice to it, but I want to make sure I can grind down the things I think I can. Thanks. I will be post mine tomorrow cause my batterys are to low right now.
u mean my 2.3 mani and all the work I did to it
Friday, March 25, 2005 7:31 AM
you can grind off all of the little protrusions of metal on the manifold the only thing you might want to leave is one of the threaded ones near the front to mount your MAP sensor to. I shaved several of the main ones off and im very happy with how it turned out. Im workin on the car later ill post pics then.
Friday, March 25, 2005 7:32 AM
a had a freind grind off the little pieces above the map sensor closest to the manifold and the one all the way in the upper right. you probably could grind off one next to the map sensor also..
-- MyZcar
Friday, March 25, 2005 7:59 AM
there is already a post with pics for the HO intakes
SEARCH YOU LAZY A$$$
Friday, March 25, 2005 8:01 AM
ILL EVEN GIVE YOU A CLICKABLE LINK FOR IT , EVEN THOUGH ITS ABOUT 2/3'S DOWN THE PAGE !!!!!!!!!!!!
http://www.j-body.org/forums/read.php?f=2&i=279568&t=279568
