safc wiring on a 2200 - Performance Forum
Thursday, March 24, 2005 4:04 AM
I decided to go turbo and was looking for a wiring diagram for the safc2. since they didn't make one for our cars and everyone on the site that said they had one wired up on a 2200, but never posted a diagram. I figured I would look for an option and see what people think. I was looking at the different wiring diagrams for the unit and the connections seem easy enough to understand. Here's were I am looking for peoples opinions and thoughts. Looking at the ny.j-body site at the pcm diagrams.
2200 pcm
then looking at the 2.4 pcm diagram
2.4 pcm
all the wires are the same expect for 3-4. The colors are the only things that changed on the wires.
also on their web site if you scroll down a little further there is an install of the afc on the 2.4, as well as tuning for it.
afc install
what do people think?
Re: safc wiring on a 2200
Thursday, March 24, 2005 4:25 AM
As long as you get the connections where they are supposed to go, you'll be just fine.
(aka Tach Wire to Tach Signal, Map Wire to Map signal...)
Thursday, March 24, 2005 4:45 AM
so after you install the unit and reset it. does the unit run what your car start up as or do you need to tune it before you drive?
Thursday, March 24, 2005 6:06 AM
You set the initial settings for the sensor types and whatnot, but if you leave the fuel adjustments at 0% it will run your factory fuel map.
