lemme tell ya, what an experience, so much fun, that crappy pacesetter paper gasket is a major pita to remove, but the stock gm gasket goes on smooth.....so when installing a pacesetter header, take your stock gm gasket and use it instead of the pacestter one, it sucks big time
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Um........Thanks?
Why did you even install the paper one in the first place if you think it is so bad?
Or did you have a shop install the header and didn't realize that there was a paper gasket on there?
Mine didnt even come with a header gasket.
I used my paper one, works fine.
i didn't know that it was paper, i had a shop put it on along with my exhaust system.........paper just isn't a good idea for an exhaust gasket
Hail Satan
I got the gasket we just used the stock gasket and after the install we said "we forgot to use the gasket Oh well"
all the time
the gasket works fine for me
(Insert really cool picture of my car with some catchy name or slogan here)
its not paper , its just white
its a kevlar composite gasket
is it? well it felt like paper.........either way, i perfer the gm metal gasket, it seals better, i guess the pacesetter unit is hit and miss, guess i missed
Hail Satan
mine came w/ pacesetter....works fine
the biggest thing is to make sure and re-check all the nuts and bolts after the first heat cycle , and every day or so for about a week to make sure they stay tight
also its usually recomended to use a light coat of high temp silicone on each side of the gasket
once u get a header installed your supposed to tighten the bolts every 2 days for 2 weeks and then after that it should be tight forever...i learned the hard way blew my weapon r gasket after 3 days.
MY 2003 SUNFIRE
