Hey Guys, got my motor mounts installed and i was just wondering what motor mount vibrates the dash? is it the upper insert or the lower mount... or both??? my dash vibrates and i am looking for a quick solution. If it is the upper mount i could just take it out i guess as the only thing i really need is the lower mount...
I would say the lower. I only have the upper and there is very little vibrations. and most people say they gained the vibs from the lower also.
![](http://registry.gmenthusiast.com/images/venomcharged/sigsunfiresresi.JPG)
^^Home made sig^^ ghetto, I know.
http://members.cardomain.com/blackoutfire
i put both in and its not to bad. i had just the bottom in and thats when it shook like crazy. it still shakes but i think it is kinda of worth it. it puts more power to the ground.
The lower create the most virbration. Get use to it or get rid of them.
Auto tap screw help a lot too
zouiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
-What's that noise?
-nutting, it's just my neighbour racing can (read civic).
you guys couldnt be more wrong
its the combonation of the 2 , if you use 1 or the other its not as bad
in both of my cavs , ive had the lower 1 in first , cause it was easier for me to put it , and its not very noticable
if you have a 5spd i recomend getting the trans inserts also
mine vibrated like a bitch when i first installed them, after a few weeks and some dynamat the vibrations have gone away...so either fix it like that or find another way. but that way worked well for me...i found out most of the vibration comes from the plastic part of the dash that is closest to the windshield.
