2.4l cavi boared 010 over, new pistons, rings, secret cams, cold air intake, complete exhaust, 2.3 HO manifold and TB, crank pulley. take a guess. once my car is all put back together, im hopoeing in the next month or two i will dino it and c what whp the car has. so take your best guess
more than 160...but not too much more
what does the 2.4 have stock
your building your engine and you dont even know what it has in hp in stock form??
its 150 hp and 155 tq
Damn so what are people on the ORG now, dynos??
Man I have seen this topic arise at least 3 times in last 2 weeks, this is a really ridicoluos question to ask.
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's
----12's
----11's
----10's
Agreed, very ridiculous question. NOBODY can guesstimate your power at the end of all that.
First off, what compression pistons are you putting back in? Nobody knows.
Second, you're not porting out the head... why not? It's off the car...
Third - You didn't state the size of your exhaust... so........ another wild guess.
Lastly, nobody is going to be able to tell you. If you overport the heads for the cams you'll lose power (I know this personally)... if your exhaust is too big you'll lose low end torque... if you don't install the 2.3 H.O properly you'll lose airflow, etc etc etc etc etc.
Too many variables, too many things to guess at. All I can say is build it and see for yourself bud.
And if you want to flame me, go ahead. I already built up an N/A LD9 with every bolt on possible without going totally hybrid. I've since moved on to something that will provide real power on this engine.
-Chris-
-Sweetness-
-Turbocharged-
like 99redz24 said you have 150hp, but depending on your elevation you might see less.. a Stock 2.4L in Calgary puts out 130hp at the wheels. Calgary is 3,440 feet (1,048 metres) above sea level
5 million catrillion bobillion fofillion gillion hp
sounds like a smart move if you ask me...nobody will be able to touch that
all the v8s will be crying when they get beat by a 4 banger thats that beefy
come one guys, he said just take a guess, i'm guessing he means just take a stabe in the dark for sh*ts and giggles. and if he doesn't mean that, then big deal, just throw a guess, let him dyno it, and be on his marry way. also freebs, the 2.4 doesn't kick out 150whp stock, that is 150bhp. just thought i would clarify. i personally have no guess as to what it will kick out, i'm just trying to say, give him a break.
i am guessing the horsepower numbers wont be anywhere near a turbo system based on the same budget of all the work your doing.
I'd give you 165whp ...... if you have a lightened flywheel as well.
For sure....
JDM Civic Hatch
nowhere near 165whp. it's closer to 180bhp.
Let's check it out.
Bore block and pistons - .010 is nothing - 5hp
Secret cams - 10hp
CAI and exhaust - 10hp
2.3 manifold and Tb - 5-10hp
Crank pulley - 0hp
So at best it's around 185. You'll be closer to 155whp tan 165whp.
Gilles
2.3 Ho
