will any of these mods throw a code - Performance Forum
Friday, March 11, 2005 12:06 AM
i will probably be doing most of these mods to my 99 Z24 this summer, will any of these mods throw a code, and can all these mods be used on a stock computer (no flashing needed)
- secret Cam Swap
- Hi flow Cat/2.25 pipe and 4-2-1header
- fuel regulator
- bore the engine
- HO intake from 2.3 and 2.3 TB
- and finally HIGH OUTPUT alternator.
Thanks in Advance,
Re: will any of these mods throw a code
Friday, March 11, 2005 6:13 AM
bore the engine????????You mean stroke it? Read up more before you start modding there is an FAQ at the top of tha page. Though some of those things do sound like a good plan
-secret cams (great idea)
-Hi flow Cat/2.25 pipe and 4-2-1 header (I would suggest a 4-1 header)
-fuel regulator (not needed without way more mods)
-bore the engine (I think this is one area you need to read up)
-HO intake and TB (good again needs some modifications to fit but still good plan)
-HO alternator (unless yours is in bad shape no need for this)
Other mods to consider:
-Port and polish the head
-light weight crank pulley
-New engine mounts
-New transmission mounts
Check out my profile for other ideas.
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
Friday, March 11, 2005 6:15 AM
Oh and you shouldnt throw codes from that stuff as long as its done right.
Friday, March 11, 2005 6:41 AM
Boring the engine requires a rebuild, so new pistons, bearings, rods, rings, all that fun stuff.
Friday, March 11, 2005 6:48 AM
if youre getting a header, go to www.justmagnaflow and get part number 94035 for your converter. if you are not getting a header, get converter p/n 91035
Land Pirates sail the open roads
DISCLAIMER: If anything I say offends you, I don't care..wear a helmet. Also, the information
I post is what I know to the best of my knowledge. If I am wrong, please correct me so that
others as well as myself may learn.
Premium sinc 6-17-04
Friday, March 11, 2005 9:23 AM
Actually The FAQ forum is where i got the idea to bore the engine, All it said was a 2.4 engine can be bored to 2.7.....And i'm doing a rebuild on my 2.4 this month, so since its already being honed, i might as when bore it a bit, i know i have to buy new pistons and rings, etc............I forgot to also mention the port and polishing, i will also do that when i start to dremel the Quad 4 intake manifold....... And YEs, the HO Alternator is the most important mod, the stock alt can handle my 3 amps, i already replaced it once. just wondering if the stock computer could handle all the extra amps (220amps)...And i can't do the underdrive pully system cause i that will cause my alternator to spin slower, and that the opposite of what i want...
Will a 2.3 crank from a LO quad work on my 2.4? would that make a difference?
Friday, March 11, 2005 9:33 AM
You are mixing up what electricity does. The alternator is capable of putting out 240 amps, but that doesn't mean thats how much goes through the electrical system. The computer draws so many amps and it won't draw any more.
Don't bore your engine out that far, the sidewalls get crazy thin. I would go .040 over at the very most.
