mechanical water temp gauge hook up - Performance Forum
Wednesday, March 09, 2005 8:44 AM
i was just wondering if i can remove the old water temp sender for the cars and replace it with a mechanical autometer one without screwing up the computer
Re: mechanical water temp gauge hook up
Wednesday, March 09, 2005 8:46 AM
No, you can't.
Wednesday, March 09, 2005 9:06 AM
the computer has to know the temp of the motor
you would have to make a T of some kind in order to use both temp sensors
Sunday, February 03, 2008 7:42 PM
Back from the dead..
Does anybody know if you can just tap the yellow wire for the temp sensor on the side of the 2.4 head to get a reading?
Sunday, February 03, 2008 8:33 PM
You'll need what's known as a hot water box. Summit & Jegs carry them, It goes in-line on the heater hose and you can put your mech temp gauge probe in it for a reading.
Go beyond the "bolt-on".
Sunday, February 03, 2008 10:10 PM
DatWhitecavy wrote:Back from the dead..
Slowolej had told me before that you probably can't. You could just T off of the coolant sensor passage in the plastic water outlet and put another sensor in there. I have a metal Quad4 outlet, but with it T-ed it still reads the correct temperature (from both sensors). I believe it is 3/4" NPT.
"Youth in Asia"...I don't see anything wrong with that.
Monday, February 04, 2008 4:52 AM
Thank you guys for the info
