Where can i find an aluminum head for a 1999 cavalier 2.4??
why do u want one? a little weight reduction and it gets hot faster, get ur stock one port and polished, will be hell of a lot cheaper than a whole new aluminum head
i think stock ones are cast aluminum. i think.
<img src=http://registry.gmenthusiast.com/images/slowgreenfire/cig%20copy.jpg>
it's not ghetto, it's "in progress"
Yep stock heads are Cast Aluminum. I think the blocks are too... but im not sure about the blocks, but i do know that the heads are for sure.
Ecotec Block is Alum. 2.4L is not.
Both heads are alum.
wow. The head is aluminum on all 2.4L, and the block is steel.
Only Ecotecs are all aluminum.
oi vey....
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
block is iron. head is aluminum. this is true for pretty much all GM for the last 15 years except for the ecotec, northstar, and you few lucky punks with a ZR-1
geez. alot of people guessing on the info here. if you dont know, its not going to help to guess the answer and then say to not may attention cause you dont really know. are you just trying to get a high post count? only post questions and answers. misinformation is the devil.
the 2.4 is an iron block with an aluminum head.
<a href="http://www.j-body.org/members/speedvisioncavalier"><img src="http://www.j-body.org/registry/speedvisioncavalier/new%20sig.jpg"> </a><img src="http://www.precizion.org/animatedz.gif">
"What are we going to do tonight?"
"The same thing we do every night, try to make the SVC go faster!"
chapter10 wrote:block is iron. head is aluminum. this is true for pretty much all GM for the last 15 years except for the ecotec, northstar, and you few lucky punks with a ZR-1
actually you are partially correct
the caddie 4.1 was a aluminum block , with cast iron heads , LOL
the LS1/LS6 in the vettes and F-bodies are all aluminum , the 4.8 and 5.3 trucks got aluminum heads , and the newer 6.0 got the aluminum as well , the older 6.0 had cast iron
speedvision , i think more were being sarcastic , than guessing
the ohv, eco, and 2.4 all have alum heads
<smashes head on desk>
