the header and catback are desighned to bolt to the oe cat but after you swap it out with the mangaflow one wich dosent have the flanges how to you connect the header and the catback t the cat......???? do you have to weld um>??
Matt
What day is it again?.... I don't sleep enough.....
you will have to have some pipe added to keep it 2 1/4" all the way through
unless you reuse the stock cat , you will need have pipe added to the back of the cat and a flange
on both sides or just the rear..?
Matt
