does anyone have detailed instructions on how to install them effeciantly and easy. pace setter 2.2l -if some1 could send them that would be helpful
or a link to a site to explain on how to install w/ deatil and pics.
So how'd the install go?
I know that it helped me out alot
'99 2200 LS CX1 Sport
QUOTING THAT SITE:
"12. Working from beneath the vehicle, the new headers were slowly raised into place."
headers? lol
installing a header on a jbody is tricky only because its hard to get fitted and you have to remove the alternator / belt. however, the concept is quite easy. unbolt manifold, unbolt b pipe, replace gasket, replace manifold, replace b pipe. as a side notice, be VERY VERY careful with the bolts holding the b pipe to the catalytic converter flange. they like to break off into the cat (DO NOT USE AN IMPACT ON ANY OF THE FLANGES EXCEPT FOR THE COMPRESSION SPRING BOLTS FROM HEADER TO B PIPE). otherwise... you will have to replace the cat and flange. trust me, i've been there.
