Hey... I was looking at the silver j-body gallery, and noticed that your front neon light doesn't show. How did you mount that, and where? I have my 31" red one... but I can see the bulb (doesn't light as I'm waiting for my replacement 52" for my passenger side). Thanks in advance
dude not to be mean about it, but just stuff it up in the bumper and play around with it til you cant see it. Mount it on the front frame guard at the top of it and you shoud be fine.
I kinda played around with it when I first installed it. I lost the clips for the front, so I used some wire ties (zip ties). Just wanted to know if it was more up twords the hood, or more down twords the bottom of the bumper.
Well I COPIED william's neon's that were installed from BestBuy where he work's and put it behind my shroud held in place by zip tite's.
hmm... I'm gonna take a look tomorrow
I used four ziptie's. Me and will held the neon up to the shroud then pre-drilled the hole's with a 1/4 inch drill bit (cause we used the thick tie's) just above and bellow where the tube is. I haven't had any problem's and it doesn't shake loose.
