tan cavalier headliner for a sunroof car, has everything and in good shape
2.4 power steering pump
2.4 head with cams and full valve train
2.4 power steering pump pressure side hose (brand new)
2.4 throttle body with sensors
2.3 HO injectors
95-99 air bags with sensors and everything to work
2.4 block with 2 cranks
2.4 rods/pistons and full bottom end
2.4 intake manifolds
idi covers
MSD 8.5mm spark plug wires for a 2.2 or 2.4 coil swap (brand new)
2.4 coil packs and icms
2.4 stock springs
autometer ultra lite narrow band a/f gauge
trunk net
AEM 3" cone filter (brand new)
rear fender liners like off the 03+ cavaliers (brand new)
12" rotors for rear big brake kit, someone will have to fab something up though
3/8 -> -6 quick connector with -6 stainless braided line and includes the fitting for the fuel rail thats threaded to the -6
spec lightweight flywheel for a 2.4 (needs a new friction plate) $125 for the flywheel and $200 for the flywheel and i get the friction plate for you
5x black 2.5" reinforced couplers
1x black 4" coupler
1x 2.5" t bolt clamp
2x 2.75 t bolt clamp
misc -10 aeroquip fittings
45* part # is fcm 4024
90* part # is fcm 4034
60* part # is fcm 4084
arp headstud parts for a 2.4
have the washers/nuts and 2 of the short studs, can get the long studs no problem and ship as a full kit
What do you want for the arp headstud set complete? I wouldnt mind having a second set.
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
onecleancavy wrote:What do you want for the arp headstud set complete? I wouldnt mind having a second set.
id have to call and see how long it would be to get the long studs in pending the shipping order and see what pricing is.
for headstuds, you should only need the one set
Spec Flywheel for Isuzu or getrag transmission?
Depending on price I may be interested in the Arp head studs as well. Is what you have new or have they been used?
Scott what are you looking to get out of the fender liners?
LAFNGAS wrote:onecleancavy wrote:What do you want for the arp headstud set complete? I wouldnt mind having a second set.
Should only need one yes, unless you planning on building another block while you drive this summer
03 Cavalry wrote:ill give you $10 for the air filter.
already sold
DSMskyline wrote:Spec Flywheel for Isuzu or getrag transmission?
Spec flywheel for the getrag
i still have to find the price for the other studs to make the full kit so i would have to see $ to get the long studs
WHITECAVY wrote:Scott what are you looking to get out of the fender liners?
shoot me a pm
bah, what ive you wanna build numerous engines? LOL
head studs sold? if not how much shipped to california
Spec flywheel paid for.
Did david ever buy them?
How much shipped to 44057, Ohio, USA?
I still want those arp headstuds as a kit pleeeeease
Shoot me a pm if your stil able to peice together a kit
Do you have the part numbers for the rear fender liners?
how much for the 2.4 block and im asuming the two cranks are stock correct?
MEAN & GREEN.
totally forgot about this
what you want for the 2.3 ho injectors?/ email me at jharrisaf2@gmail.com..
what do you want for the AEM filter? Mine is beat to hell and needs replacing.
I am looking for struts for my newly aquired Eibach pro-kit performance coils, If anybody has some?
air filter is already sold.
I need a new sig.
also have 2.3 HO cams modded for the 2.4 sitting here
Have a price in mind for the cams?
