idling problem - Maintenance and Repair Forum
idling problem
Thursday, December 29, 2005 3:48 PM
got the car started, runs good but is idling all over the place, at first it was staying at 4,000 rpm steady no matter what, and now it surges from 1500-2000rpm constantly and is annoying as hell
Re: idling problem
Thursday, December 29, 2005 3:50 PM
also is there any way to adjust the idle on these cars?....its a 97 cavalier z24, 5spd
Re: idling problem
Thursday, December 29, 2005 4:27 PM
iv got a cel and i cant keep it at constant throttle or else it bogs for a second
Re: idling problem
Thursday, December 29, 2005 5:59 PM
well if there is a cel i'd try to putt down the road to autozone or wherever and get them suckers read. then you;d probably know what is going on and not just start throwing money towards the car HOPING to fix it.
Re: idling problem
Thursday, December 29, 2005 6:06 PM
IAC Motor isnt plugged in, mine came disconnected once, and i had the same CEL/Issue, plugged it back in, and it seemed fine afterword. If its plugged in, im betting the motor is bad, or needs to reset somehow.
Re: idling problem
Friday, December 30, 2005 6:00 PM
another funny thing iv noticed is the car wont heat up like normal, it will just barely got past the 45 mark, not to 90 like it usually used to....and it wont let the rpms drop any further down then 1500rpm, its lik when i let my foot off the gas instead of the rpms dropping it jsut stays and keeps itself going instead
Re: idling problem
Saturday, December 31, 2005 3:19 PM
i just hooked the car up to a code reader and it said i had 1 code, it was po507 "idle control system rpm higher then expected" like no @!#$ @!#$, lol........any ideas what the hell that useless code means?
Re: idling problem
Saturday, December 31, 2005 10:46 PM
also if i give it steady throttle it trys to bog out and jerk for a second, do you guys think this is the iac?
