hybrid engine, what gasket set to start with? - Maintenance and Repair Forum
Tuesday, December 13, 2005 3:28 PM
well, i'm rebuilting my engine (97 2.4L) and putting the 086 head with HO cams and was wondering if i get a 2.3L gasket set, which are gonna fit to my 2.4L? i mean if the timing chain housing gasket the same, water pump, oil pan.... things like that?
or i'm better of buying a 2.4l set and buy the 2.3l one apart or just get every gasket apart without buing a kit???
I alrady have the cometic head gasket....
thanx!
Re: hybrid engine, what gasket set to start with?
Thursday, December 15, 2005 1:37 PM
anyone please?
also where is the cheapest place to buy a kit?
thanx!
Sunday, December 18, 2005 6:57 PM
cmon people!!!!!!!
Sunday, December 18, 2005 7:23 PM
it would be fine
you man need a lil trimmin on the headgasket set, where the waterjackets are.
the other gaskets should be the same.
for the 2.3
or the 2.4
you really only need the 2.e intake and exhaust gaskets..then use the rest from a 2.4
Monday, December 19, 2005 3:03 AM
no trimming is needed on the head gasket! I'm using a 2.4 head gasket, not a 2.3l
i need intake, exhaust, cams from 2.3.
i was wondering if i buy a 2.3 gasket set will any other 2.3 gasket will fit the 2.4 parts like the oil pan, water pump? are these the same from 2.3 to 2.4?
thanx
Monday, December 19, 2005 3:11 AM
the 2.3 oil pand gasket doesn't fit with the 2.4 pan. They're different. No gasket for the oil pump on the 2.3.
Gilles
2.3 Ho
Monday, December 19, 2005 3:25 AM
huh... didn't say oil pump, but water pump!
what about the timin housing gasket?
thanx
Monday, December 19, 2005 10:20 AM
My bad about the oil pump. Use the 2.4 gasket for the timming chain housing and cover.
Gilles
2.3 Ho
Wednesday, December 28, 2005 7:35 PM
if you are using a 2.3 head the 086 on a 2.4 you need to make the water passage hoels bigger on the 2.4 gasket. or else it will overheat ask sunfightergt i think he did it.
Wednesday, December 28, 2005 7:42 PM
yeah, thats what i thought! i have the cometic head gasket N/A version and the holes are sooooooo tiny.... how big should i do them? anyone knows?
thanx.
