I have DC sport, 4-1 headers that are nylon taped, and a borla cat-back system installed on my car. I got in this cold morning and started it up, and it was at a really rough idle. It seemed to smooth a bit out at high rpms. It's really rough and lacking power in the low RPMS. I got out of the car after driving it for 10 mins locally, and looked under the car, only to notice from the back of the Cat, right up to the start of the muffler, it was glowing red hot. The headers and downpipe were fine, but it started at the very end of the cat. I have no idea, only to think it's a clogged cat because it's sputtering and and has a really rough idle. Keep in mind it's 30 degrees out here, and it still managed to glow red hot. Any input would be helpful guys.
Well it may or may be the cat. It could be clogged and thats causeing it OR it could be you have too much fuel getting into the engine and the poor cat is working overtime trying to burn off the excess fuel and thats causeing the glow. Is the CEL on? if so get the codes checked before you just start replaceing parts as that tends to get expensive. If there is any codes see what they are.
It might help to know what car you have, with what engine.
Clogged cat my friend. Those are the classic signs of it.
Brian
Yeah, and wrapped header doesnt help IIRC, doesnt it make it hotter too, or isnt that the idea?
id actually be looking at a the muffler
usually the cat will cause the pipes to heat up before it , not after
if you havent noticed anything before that morning someone might have shoved something up the tail pipe
or the cat did come apart , and clogged the muffler
also wraping the header is not good for a street car, it will cause the header to fail , and blow out
id pull the cat back pipe off and start it and see how the motor acts , and also if there is a white sandy grit in the pipes , which would be the cat coming apart
[quote=97cavie24ls(JDM&00s/c sedans™)]id actually be looking at a the muffler
<img src="http://home.att.net/~lls4849/iagree.gif">
IMO, this is good advice.
Thanks for the help guys. I finally got an engine code to read. haha, says "multiple cylinder misfires". SO i'm thinking spark plugs or my coils. I'll take em out tonight and see if they spark or not. I've heard from people that the bosch platinums might be the source of the problems. I've sworn by them in the past, but now i'm questioning myself. I'm going back to the stock AC/delco if they are. Thanks again...
So the engine was mis-fireing causeing unburned fuel to dump into the cat. Hmm?
Sounds almost like what I said.
Glad you found it out before it made your cat go bad.
or the cat did come apart , and clogged the mufflerquote]
my thoughts too. another thing that can cause it is an EXTREME lean condition
here's an off beat thought too. there is such a thing as a Field Service mode, this is done by connecting two pins in the DLC 9dant remember wich two) and it will set EVERYTHING to base (timing:spark/ign, and will basically ignore ALL sensors not needed for engine to be running. what this will cuase many times is the exhaust to glow red hot b/c it causes certain conditions (i.e extreme lean condition) maybe somethign shorted out. very implausable, but possible, and just sum food for thought
As a heads up, i finally got time to work on my car this past weekend. I found out that plugs 2 and 3 aren't firing, 1 and 4 are working correctly. So i took my Iginition coil, and started to ohm out the pins, thinking i could find something, but i have no idea what i'd be looking for to prove it bad.. The ignition control module could also be bad. I'm not sure what i can do to find which one is bad. I'm going home for the christmas in 3 days, and i have to fix this for the road trip. Thanks for any input on which one to pick.
Tom, If you go to Advance Auto they have in their computer system the specs for all the coils as to what the ohm values should be and the exceptable levels that the manufacturer says are ok. They also have a tester for certain moduals, you'll need to pull it off and take it into the store for testing, same with the coils. Now true some moduals can't be tested but if I remember correctly the Chevy ones aren't a big deal.
call and check before you go so they can double check that they can test yours.
And good luck
it probably is the module, had the same problem with my company car. we put an aftermarket module on and it was running like crap. we decided to put an a.c delco on and it solved the problem
BirdmanXXXXX!
