Bad motor mount? - Maintenance and Repair Forum
Bad motor mount?
Thursday, December 08, 2005 7:11 AM
I just got my pacesetter header on the other day i have a polyutherane lower engine mount and the stock uper mount, i have the ecotec could my upper mount went bad?
Re: Bad motor mount?
Thursday, December 08, 2005 7:24 AM
I don't understand your posting? Why do you THINK you may have a bad motor mount
just because you installed your header? Please clarifiy.
Thursday, December 08, 2005 8:07 AM
because the engine is shaking like crazy now.
even when idle.
Thursday, December 08, 2005 8:44 AM
Ok, now that makes sence. It started right when you put the header on? I'd have to guess something wasn't done right with the install. Go back and double check everything you did. if the problem started exactly when you installed the header then
its probly the cause in one way or another.
Thursday, December 08, 2005 8:49 AM
well my dash has been rattling pretty hard for the past week or so even before the header install i just never checked it out....i don't believe a header would cause something to shake like that, i've always heard the ecotec upper mount is weak anways.
Thursday, December 08, 2005 10:07 AM
Ok then that is an existing problem. I thought you were saying it started from the header install. Sorry for the confusion. Anyway I haven't heard they are weak but I'd say check it out anyway.
Thursday, December 08, 2005 12:22 PM
i thought simply by installing a lower mount it made dashs shake....am i wrong?
FACT : Statistics show that you are more likely to to be hit by lightning than to die street racing.
FACT : It is our American RIGHT to own a GUN but not to drive a car.
"Those who would sacrifice freedom for saftey deserves neither Freedom nor safety!" - Benjamin Franklin
"The real destroyer of liberties is he who spreads among them bounties, donations and benefits." -- Plutarch
Thursday, December 08, 2005 5:34 PM
yes, you are correct, its just my engine shakes somewhat....is that normal for your engine to shake whenever idle? It dosn't shake all that bad just somewhat its visable for sure. My friend suggested that it could be where i added the header that the engine would run a bit more rough since it is getting more flow, though I am not sure.
Thursday, December 08, 2005 6:32 PM
How does it run? can you tell is a bit faster or slower?
(after installing the header)
Thursday, December 08, 2005 6:35 PM
it runs quicker not slower.
Thursday, December 08, 2005 6:52 PM
I think you're okay then.
Maybe if you get the upper and lower engine mount might help.
if the engine moves back and foward everytime you give it gas then you have a broken mount.
Thursday, December 08, 2005 7:14 PM
it dosn't do that it just shakes when its idle not bad though.
Friday, December 09, 2005 8:15 AM
I read before that when you put aftermarket engine moutns on the Ecotec, that it does cause a lot of vibration regardless.
