z24 foglight assembly problem - Maintenance and Repair Forum
Monday, December 05, 2005 7:40 PM
im about to head to bed, and wake up freakishly early in a few hours so i want to post this asap....thanks in advance btw. recently my fog lights wont turn on when i turn the knob to the On position. often times it will turn on, but then if i leave the switch on the On position when the fogs arent working, it'll turn on by itself after a few minutes of driving....only happened a few times, not all the time. so im wondering if theres a fuse that i should check to see if its goin bad, or if theres a possible tear alongside the fog light harness. if its the harness, then woulod i need to look on the driver's side? considering that the passenger side goes and connects with the driver's side then into a bunde back into the firewall, would the bundle be the place to check? considering that its beginning to snow here in the states having my fogs work is sometimes better than having my headlights when driving against the snow. again thanks in advance.
Re: z24 foglight assembly problem
Tuesday, December 06, 2005 7:14 PM
^bump sorry about that
Wednesday, December 07, 2005 9:52 AM
Just a suggestion, Check the actual switch connection. You have to take apart the dash and check the connections. They might be loose.
Hope this helps.
Wednesday, December 07, 2005 2:01 PM
ah ic....PITA to take the whole dash out lol...i wasnt sure if it would be a connection problem from within the engine compartment or inside the car/dash
i'll look into it this coming weekend. wish me luck.
