Heat Problem... Please read.. Confusing - Maintenance and Repair Forum
Saturday, December 03, 2005 5:45 PM
Ok I am ahving a heating problem, yes I read the faq but what my problem is isn't listed
ok I start my car in the mornings or when I leave from somewhere and the heat works wonderfully 9cold but blows rigth speeds) the second the car is sorta warmed up it stops blowing air.. I will get on the gas really hard and shift hard and whatever and the heat comes back on for a split second or 2 but at a fraction of the force and then shuts back off... any suggestions?
(no ac it was removed)
LE61T PTE6262 Powered
Re: Heat Problem... Please read.. Confusing
Saturday, December 03, 2005 5:54 PM
The blower might be hitting part of the shroud. When it gets warm it expands just a tiny amount and starts rubbing. When you get the rpms high, your voltage will go up slightly possibly giving it just enough to break free. Or the bearings might be going bad and causing the same symptoms as described above.
Just a guess.
Saturday, December 03, 2005 8:20 PM
Your blower motor has worn brushes if you tap on the blower the next time it stops and it jumps back to life that is for sure what is wrong.
Thats Him Officer The WICKED One.
Sunday, December 04, 2005 12:12 AM
thanks!!
it used to hit something we heard it, sounded like a baseball card in a fan and that sound eventually stopped... but now it doesnt work
Sunday, December 04, 2005 12:39 AM
That's the fan hitting the shroud. I had a camaro do the same thing. I just took it out and adjusted the position and put it back in. worked great after that.
Sunday, December 04, 2005 10:40 AM
ok, we'll def. look into it!
