HELP!!! I Dropped my dipstick - Maintenance and Repair Forum
Thursday, December 01, 2005 3:32 PM
Hey guys,
I need help. I was changing my transmission fluid and i placed the transmission fluid dipstick over the battery. Well i dont know what it is called but i also removed my airbox and ther is a tube that leads to the fender of the car where the intake gets its air from, but i dropped the dipstick in that hole and now i cant get it. How can i take that tube out or what can i do as a temp fix.
-Will Ong
Re: HELP!!! I Dropped my dipstick
Thursday, December 01, 2005 5:00 PM
Did you just removed the Air Filter and the Cover off?
that's not the air box.
To remove the Air Box, you need to remove the battery and your battery is still there.
Maybe you need to remove the air box; the real air box
Thursday, December 01, 2005 7:28 PM
Either get a magnet on a string to pull it out, or jack up that side of car, remove wheel, remove inner liner. And remove air bong. Ckeck the library as how to do it, but your car will be better without the air bong anyhow. then take airbong, turn it upsidedown and dipstick will fall out.
Thursday, December 01, 2005 7:29 PM
Robby002 wrote:Did you just removed the Air Filter and the Cover off?
Why do you need to remove battery to get to any part of the intake?
Friday, December 02, 2005 7:58 PM
Probably to get more room........make it a little bit more easier ......but i know you dont have to...
Friday, December 02, 2005 8:40 PM
you have to remove the battery if you want to take the whole airbox off the car..
