i have a 97 cav w tilt
i tried to take my ign switch off,but found that u cant use a nontilt column switch on a tilt column switch
i went to put it together but now i have aproblem with the bearings
the column seems to sink down in u have to pull on it(the shaft)
i got everything off including locking plate, airbag, wheel.
it seems that the cup that holds the spring in place. i dont know if it is going in rite dir? does the cup hold the spring or turn it around and support the bearing? everything is loose
the shaft has lots of play in it
i dont think im missing anything
can anyone help w/ pics, diagrams?
