z24 hyd or cable clutch ?????????? - Maintenance and Repair Forum
Tuesday, November 22, 2005 2:29 PM
I just bought a new z24 and the clutch was great, when i was driving home today all of a sudden the pedal just became really loose. i also have problems going into second gear if i pull on the shifter harder then normal (racing). I get a little bit of a grind
is this a hydo clutch like the 2.2 or a cable. Im new to these cars and i need help !!
Re: z24 hyd or cable clutch ??????????
Tuesday, November 22, 2005 3:01 PM
Hydrolic clutch, used it from 95-05 and maybe even before that . A far as the grinding, it could be anumber of things. Could be bad slave cylinder, the clutch itself might be junk, your tranny could be bad if grinds into second, might have a bad master cylinder. Could be an number of things.
I am what I am and it is what it is.
I am the 2nd most untrusted person in the world next to a lawyer,welcome to our dealership, may I help you?
Tuesday, November 22, 2005 7:32 PM
sounds like a clutch problem to me
Tuesday, November 22, 2005 7:37 PM
I'm thinking the same thing, i had that similar problem on my 95 Z, now that I think of it.
Tuesday, November 22, 2005 9:11 PM
i think it's gonna be a slave cylinder. If it was leaking, it will make it not move the clutch plate far enough to completely disengage thus making gears grind when driving hard. if this went on for an extended period of time it may have fucl<ed ur synchro(s) up.
check to see if your slave cylinder blew out and go from there.
Wednesday, November 23, 2005 4:14 AM
bleed the line first before you start replacing anything
