fuse problem - Maintenance and Repair Forum
fuse problem
Saturday, November 12, 2005 5:12 AM
ok here is the problem i have a fuse that keeps blowing every time i turn on hy headlights it is the fuse that controls the dash lights and driving lights i dont know why it keeps blowing please help
for sale pm me or e-mail me for details
Re: fuse problem
Saturday, November 12, 2005 5:59 AM
Fuses will because of a dead short or a grounded short, fuses will not blow due to an open because that simply extremely high resistance.
A dead short is where the power wire goes to a ground before any load, in a grounded short the wire goes to a ground you dont want after X amount of loads.
Take a 12V test light and put it where the fuse goes. Turn on the headlights. Now you need to open connectors one by one. You want the test light to go off after you open a connector, that means you broke the circuit. If the test light stays on and it is before another load in the circuit, than you have a ground before the next load and after the last connector you just tested.
Re: fuse problem
Sunday, November 13, 2005 7:03 AM
ok well i did what you said and i found a bad wire going all the way up to the steering column i replaced that wire and i also found a brown wire that i have no clue where it goes it is all singed up from a short but what does it go to is there a wire diagram for the steering column if so i could find it easy
