Starting hard??? - Maintenance and Repair Forum
Starting hard???
Tuesday, November 08, 2005 7:01 PM
Ok here is my problem,
Occasionally when I start my car it will turn over for a couple seconds before starting then almost die, then it will start but it will sputter and just barely run for a second then the revs start to come back up and then it runs fine. It only does this once in a while and sometimes it just barely even starts.
But other time it will start right up with no problem at all.
It is not the fuel filter because that clogged up a few weeks ago, so that is new.
Anyone else have this problem? What else should I be looking for??
Re: Starting hard???
Wednesday, November 09, 2005 5:06 AM
Check that the fuel pump is running for the two sec "prime" sequence. It should do this as the key is turned on but before you crank it.
Then the oil pressure switch contacts close, operate the fuel pump relay and the fuel pump is fed from there.
I just wonder if your fuel pump relay is on the blink and you need a new one, maybe just change it as it is intermittant.
Alont.
