well i just noticed coolant bubbling through the spark plug to the drivers side of engine. i am guesing i need to pull the head what do you think. its a 98 2200 auto
yeah thats what i was thinking but its a constant bubbling with engine. im thinking maybe a crack or warpage. but i have never let it overheat and its is always at 195 warm.
does anyone else think the same
i have the same problem in my z24 i just did the plugs nothing bad happends nor do i have white smoke ect but i noticed plug on driver side is wet im not sure if its coolant or oil or what it even is
well its clear looking so im pretty sure its coolant. im going to buy chiltons any other advice for newb with basic car knowledge tring to pull head
newb and pull head dont sound right together..lol anything is poss. def get the manual and this wesite probably the best help you can get
time for a new head gasket
im not a comolete newb but ive never done this before. but i have already replaced pretty much everything else on this motor. i figure u gotta learn somewhere.
I would probably check to see if the spark plug is tight. It could be loose. I knew a noob one time that did that, but his car was EXTREMLY slow. He worked at my work. Just check that, and if that doesnt work, then just swap in a V6.
1995 Chevy camaro
www.cardomain.com/id/93camaro_zzz
yep it was the head gasket changed it and everything is fine so far
Heads and Head gaskets (from my understanding) are very commong things to go wrong on our cars. Do a pressure test on the rad. and a compression test on the block.
<img src=http://donut.parodius.com/agtp/images/GonMad.gif>
What makes you think I'm crazy?
