car over heated - Maintenance and Repair Forum
car over heated
Monday, October 17, 2005 11:31 AM
so it over heated cause i lost all my coolant. when i popped the hood on the corner of the radiator it was steaming out of it. its like a rubber piece with a metal bracket that runs to the rail. so i filled it back up and it was leaking from there. how do i fix this
Re: car over heated
Monday, October 17, 2005 4:00 PM
There is a sealant you can use to fix the seal, I think it goes in the radiater as a powder or liquid, or oyu can empty all the water, let it dry, apply jb weld and let it dry for a full however long it takes for it to dry, or replace the radiator.
I say go jb weld. If it can hold a hole in an exaust, it should work on your radiator. And its only like 5 dollars for a good amount of it.
Girls suck, buy a fast car.
