engine shaking - Maintenance and Repair Forum
engine shaking
Wednesday, October 12, 2005 10:24 AM
so i changed my mounts and it's still shaking.. but i know it's not the mounts, so what else could it be?
Re: engine shaking
Wednesday, October 12, 2005 10:27 AM
Re: engine shaking
Wednesday, October 12, 2005 12:37 PM
define "shaking" violently shaking, or just rumbling.
Can you see it physically shaking, or does it just feel like it?
-Chris
Re: engine shaking
Wednesday, October 12, 2005 2:07 PM
Andrey B wrote:so i changed my mounts and it's still shaking.. but i know it's not the mounts, so what else could it be?
Which mounts did you change? Did you go back to stock mounts or aftermarket mounts?
http://members.rankmyride.com/djtorello
Re: engine shaking
Wednesday, October 12, 2005 9:56 PM
yes i can see it shaking.. and it's pretty annoying because i installed urethane mounts (upper and lower) so now at idle the whole interior is viabrating like a rank 7 earth quake.
Re: engine shaking
Thursday, October 13, 2005 12:41 PM
Are you seeing the motor shake or stuff in the interior, because It is supposed to shake inside the cabin. That is the point with urethne mounts, it takes the vibration and movement out of the motor and transfers it into the cabin of the car.
Re: engine shaking
Thursday, October 13, 2005 2:00 PM
If it's the moter that still shaking with poli mounts, did you tighten down the bolts enough? I know with my 01 cav, the interior shook like a mofo. I even tracked down a used marks pains lower mount and bought RSM's softer upper mount. the cabin still shook like hell...
Took a friends impact wrentch to the mounts when I was doing a tire rotation, and that took away probally about 70% of the vibes I had
Re: engine shaking
Friday, October 14, 2005 4:54 PM
does it run OK?
