well my abs light keeps coming on and wanted to see if anyone coudl help me out
when i start my car the light is not on.
it comes on etheir if i accelerate or brake . and is very intermitant ( wont always coem on when i brake or gas)
once it come son it stays on .
had the abs checked and there were no codes present.
i got on a road while it was wet and mesed around. when the light isnt on and i slam on the brakes the abs kicks on but then makes a rapid clicking noise. then the light comes on . and after that the abs doesnt kick on anymore
any ideas?
Mine actually started doing this today as well.
Listening.....
Neutiquam erro.
i checked teh fuses and there fine.
i have the same problem, checked the codes and it said the speed censor, had that fixed and its still doing it. it has to be an electrical problem
I don't know if this will be any help but the first indication of a low voltage seems to be the ABS light coming on even if the abs is normally working fine.
On mine it was the main charging cable from alternator to battery had broken although the charge light still worked ie was out as the alternator was charging it just couldn't get amps to the battery.
Alont
